Any TX owners looking for XR parts?
Discussion of events in the South, roughly defined as the southeastern seaboard to Texas.
Texranger
Post by Texranger »
Howdy,
Long time member here and have had a blast with XR's for many years. Unfortunately my '86 was a victim of Harvey and couldn't save it.
I've been holding onto many parts and I think is now time to pass them on; I don't see myself getting another XR anytime soon and if I do, it will be one with little work required.
All these parts were purchased by me, installed on my XR4Ti's over the years. Some of them are new and some others are used but not abused.
Here's a partial list of the available parts:
- T5 5 SPD Manual Transmission (x1)
- Thunderbird Driveshaft (x1)
- Custom Made Driveshaft for XRTi (x1) - no adapter needed
- Narrow Body T5 Transmission cross member (x1)
- Big VAM (x2)
- PE, PF3 and a couple other ECUs
- Several styles of 2.3 Turbo valve covers (x3)
- Sierra Cosworth Euro Grill gasket NOS (x1) (very rare)
- Sierra Cosworth Euro Turn Signal stalked/switch (x1)
- Multiple 150/170 MPH Speedo/tach plates
- Front Big Brakes kit (brackets, PBR calipers, pads, Stainless Steel lines w/ fittings)
- Rear Disk brake conversion brackets (x1)
- Suspension Poly bushings - Rear Wishbone (inner & outer) and rear sway bar 16MM
- Many other Euro Ford Sierra dash/console switches
- 3" Turbo Downpipe (x1)
- Stock downpipe with heat shield - great condition (x1)
- Front Lower Control Arms - New (set x1)
- Red Koni Struts and shocks - Adjustable - (1x set)
- Custom Intercooler with all the necessary mounting, hoses and piping needed to install in battery tray (after doing a battery relocation, of course. Believe it or not, this is an area of very high air flow/pressure on XR's)
- Multiple Turbos and parts (housings and impellers)
- Hood Gas strut kit - (x1)
- K&N Air Filter for stock housing (x1)
- Upper/lower intake manifolds - Lower ported, upper untouched
- Stock radiator expansion tank - Round 88-89
- Stock Steering pump, alternators, brackets, pulleys (1, 2 or 3 bands and serpentine)
- Mustang SVO Top mount intercooler (x2)
- Many different hood vent sets
- Multiple badges, including: 2.3, Sierra, correct Ford oval for grill, etc.
I even have a Volvo B234F head that I purchased to swap but never got around to do it.
I'm sure I'm forgetting many of the parts I have available for these cars....if you are looking for something and it's not listed above, please contact me and I'll see if I have it.
Thanks,
Nic
List updated 5/31
List update # 2 - 6/8
List update #3 - 7/6
Re: Any TX owners looking for XR parts?
Good Stuff!
Texranger
Post by Texranger »
Yes sir! I also have a couple of wheel sets, a 15" mesh style set with caps and locks and a Escort Cosworth 16" with caps (imported from the UK).
Also a rare set of manual window brackets/tracks/rails, ideal for weight reduction. I'm sure there are some more parts in the attic!
Texranger wrote: Sun May 24, 2020 12:26 pm Yes sir! I also have a couple of wheel sets, a 15" mesh style set with caps and locks and a Escort Cosworth 16" with caps (imported from the UK).
message sent!
Texranger
Post by Texranger »
Above list has been updated. Thanks!
Texranger
Post by Texranger »
Updated list above. Thanks!
Texranger
Post by Texranger »
I've updated the above list again. Thanks.
