Not sure, as I haven't even removed the pads from the set I got. But just looking at them, they're about the same size as the T-Bird/Mustang caliper that was the basis for the original "DG Big Brake Kit".Frag wrote:What is the piston size in the caliper vs stock? vs pbr?
No adapter Big Brakes
This is magic to me, because Saab 900s use the same bolt spacing on their spindles as XRs - probably a commonality with the ATE brakes, but the Merkur adapters won't work on 'em because the "hat" on the rotor is too shallow. Wonder if this later Focus stuff would bolt up to them as well... ? Are the Focus calipers ATE too?
Compatible For Folks on the Merkur Forum.
Duh.
Duh.
-Ray
1985 Ford F150 - Tow Missile
2005 Subaru LGT
http://www.cartct.com
2005 Subaru LGT
Re: No adapter Big Brakes
Anyone install this on the car yet?
"More horsepower makes you faster in the straights. Less weight makes you faster everywhere."
-Colin Chapman
-Colin Chapman
Not me. And I've got stacks of the adapters for these calipers right over there.xR4rally wrote:Anyone install this on the car yet?
You mean spacers? Was wondering about that, as they should be a precision fitment-- right?
Will any of the earlier focus brakes work? I.e. brackets calipers and rotors.
Can you be more specific? What are you trying to do?dbmason67 wrote:Will any of the earlier focus brakes work? I.e. brackets calipers and rotors.
Nice info Brad.
Miguel.
89 XR4Ti Monique; Waking up a real "Night/Mare-Coor".
T5, NPR IC, PIMP ECU, Walbro 255, Dual piston BOV, Manual BC, 3" exhaust, One piece Aluminum drive-shaft, mc2 LSD, Boport 1.5 cam, Ported and polish head, big valves, 80# injectors, Bob's log, (soon HY35).
Yeah really....xR4rally wrote:Anyone install this on the car yet?
Good info if it works.
I'm about right there to do something with brakes.
No adaptor brakes? Whats wrong with this?
Works good....Bolt on limits diameter to about 283mm so compensate for heat by being HD 1.25" thick..
Weighs less than stock rotor and caliper...
Caliper pistons of known, proven correct size..125mm long pad...
WORK GOOD---and they should since this is dimensionally like what Ford used on the cars in motorsport when using 15" wheels..
John Vanlandingham
Sleezattle WA USA
CALL =-> (206) 431-9696 <-= CALL
http://www.rallyrace.net/jvab/
Sleezattle WA USA
Not a thing ...until one asks, "How much?"John V wrote:No adaptor brakes? Whats wrong with this?
My objective for sharing this info was to find a cost-effective brake solution that was somewhat better than stock, with much better availability than stock parts. Were it not for the need to figure out the brake flex line (not that it's a big deal) I would have followed through and made these functional, if only for testing purposes.
I modified your post...John V wrote: WORK GOOD---and they should since they probably cost more than what most XR's are worth now-a-days...
