Next, I've got a Duratec out of a 06 Focus. Reworked oil pan and pickup, Ranger coolant neck, Custom stainless turbo header. I have an aluminum intake flange (Will need to fab an intake plenum and runners) I might have a toyota one laying around that could be reworked. Have stock intake too.
I have an 87xr crossmember with professionally tig welded motor mounts. (Light surface rust from sitting, can be blasted once deal is made)
As well as 86 SVO T5 , or 88 TC T5, with Quads 4 Rods bellhousing (never mounted) even have a used Tilton hydraulic throwout unit.
All you need is clutch to complete the drivetrain (I believe ACT can provide)
$3000 o.b.o. might be willing to part out
Shoot me a text 805-315-8680
Duratec swap, all parts needed
86' White XR Sunroof (Sierra Cosworth Clone) Ported,Aluminum Rad/IC,T-5,LSD,Koni's,OZ Vega's 16x7/16x8,Corbeau seats
86' Red XR, Non Sunroof, Aluminum Rad/IC,Bilstein adj.
86' White XR Non Sunroof, Racecar PROJECT WIP...Duratec,VNT,T-5,Supra Diff.
69' VW Baja Bug,Full Cage,Ford 2.0L
