XR4Ti 302 V8 swap
Camaro5690
Re: XR4Ti 302 V8 swap
Post by Camaro5690 »
whitelx wrote:just don't use brake cleaner to clean the material.
Yea you might end up dead if you do. I just recently read about that on facebook.
Adam Wilson
Post by hEaT »
Did someone weld with the material still soaked in brake cleaner?
Camaro5690
Not anyone I know, but my group of gearhead friends were sharing the story. Guy cleaned the metal with brakleen, wiped it off, then tried using an acetylene torch to get the rest off. He lived, barely. But will have severe breathing problems for the rest of his life.
Adam Wilson
nathankershaw
Post by nathankershaw »
Whipped the engine out to put the feet on the mounts
Then I ran out of welding wire...damn it!
1987 Merkur XR4Ti. T5 swapped. GAZ gold coilovers. Custom rear strut brace. Polybushed everything. Mustang ten hole wheels. Mercury Tracer front bumper.
Firefox
Post by Firefox »
I point you to this article. Can never be to safe. http://www.brewracingframes.com/id75.htm Phosgene is nasty stuff.
Post by hEaT »
WOW! Thank you for the info.
Camaro5690
Thats the exact one i read on facebook.
Adam Wilson
jetrinka
Post by jetrinka »
Wow, never knew that about Brakleen. Scary stuff. Now I know what not to do..
88 5-speed, Red XR
86 5-speed, 4x2 Toyota Pickup 22R
75 F-250, 4x2 w/390
2010 Impreza (wifes car)
thedrill
Post by thedrill »
I was once using brake cleaner by where someone had cleaned the floor with some acidic chemicals, did not know that I had passed out and woke up in hospital, and could not breath in or out because of the pain in my chest.
Nasty stuff.. :cry:
Russ
Stable is vacant..
nathankershaw
NOOOOOO! Don't take brake cleaner from me!
Mounts in the exterior spray booth!
And put in the Scorpio master cylinder in place so lines can be made.
nathankershaw
Mounts bolted in.
Then dropped the engine on them!
Coming along nicely!
nathankershaw
merkurdriver wrote:Coming along nicely!
Indeed she is!
Took the engine back out today to join it with the trans before it gets shoved back in.
Need to clearance the mounts a little for where the rear sump bowl droops down behind the crossmember.
For now and because I don't really have any money to spend I'm going to keep the "old" long accesories and move the mustang rad forward. I'll need to trim the center light supports but as I plan on running Mustang foxbody lamps with no center lights I don't need the supports.
I need to make brake pipes and tidy up wiring this week then hopefully get it in next weekend.
I have family stuff this weekend so no car playing.
MODEL-Turbo
Post by MODEL-Turbo »
I am also thinking of going the way of the sbf. Yours looks great so far. My problem is time and $. O wait thats everyone. Looks great though. Gives me hope for starting mine some day.
Andy
1927 Model-T
1988 Merkur XR4TI (build in progress)
1989 Merkur XR4TI Daily
1979 MkV Lincolin showroom mint condition
1994 4.0 Danger Ranger FOR SALE 64000 miles 4x4[/color]
nathankershaw
MODEL-Turbo wrote:I am also thinking of going the way of the sbf. Yours looks great so far. My problem is time and $. O wait thats everyone. Looks great though. Gives me hope for starting mine some day.
This really is super budget, pretty much everything is either from the original Mustang or from the yard.
The get the paperwork done with the SMOG people like it says above I'm going go see if I can make the old long accessories fit with the original Mustang rad.
Really for me it's the fact that I'm English, ive never owned a V8 and probably will never get rid of this car because it was my first car after I moved here. So the solution was simple!
